How big is it? If it is small (say 10cm x 5 meter or so) I would probably hand laminate it. Careful and consistent hand laminate can easily be smooth and even.
Some more remarks:
-P, P1, P3, MP22, etc are perforation styles, used by many vacuum material suppliers. For instance Airtech. (I believe MP22 is exclusively used by Airtech).
To check datasheets, you need to log in at Airtechonline.com. A workaround is using the European website, www.airtech.lu, which has all the datasheets without logging in. (click “products”)
WL3700 perforated film at least in Europe comes only in big rolls. At Brands Structural Products I have WL3900 in short rolls, 100 meter long, 152cm wide. (some 110 yard x 60 inch)
When wet bagging, keep a low vacuum. The viscosity of the resin, the amount of breather, the perforation style of the release film, they all have an impact on which vacuum to use. With P3 film, I would go no further than 0,5 bar (50%) vacuum.
Using infusion resin for hand laminating in general is a bad idea. Better to get some slower curing agent, or a retarder from your manufacturer.
Compoflex 150RF does not need peelply or release film. It will leave a relatively smooth surface. 150RFSB will leave a peelply surface.
