I have seen that problem (bubbles) with surface coats. The adtech surface coat used to do that and that’s one reason I don’t use it. It was a real pain. I’d have to continually keep gently brushing it to get pop the bubbles.Good idea with the heat gun. I now use Ren (Huntsman) 1124, I think it is, white surface coat. Freeman are dealers for Huntsman products.
Another advantage with this product is that there is an additive (acrylic, I’m told)that makes it possible to apply it and then wait up to 24 hours before continuing the next layer. Usually, of course, one has to start laminating when the surface coat has “B” staged or a good chemical bond is not made if one waits too long. This makes it possible to surface coat last thing in the afternoon, go home and start laminating the next morning.
I’ll check on the details of the mixer.
