The cfm of a pump is not really that relevant.
For oil-lubricated vane pumps, it is important that they run within specs. Check these specs, as there are many around. I normally sell pumps which, by closing an oil drain tube, can run within 50% and 95% vacuum, or 90% and 98% vacuum. (I noted the vacuums in percentage, to avoid imperial vs metric issues)
When you start bagging, the pump runs at athmospheric. A pump does not like that. Running for too long at athmospheric will clog the exhaust filter, which then needs replacement. This already can happen within 10 minutes.
So for the cfm two things are important:
-enough to have the bag down within 10 minutes. (for large structures, before closing the bag completely, stick the vacuum cleaner hose in the bag, and extract as much air as possible from under the bag that way. You can just hold the bag around the hose with your hands, it is not critical. But at least a couple of square meters of air will get extracted. (1 m3 = ca. 33 ft3)
-enough to keep up with resin flow into the bag, when infusing. (at the pressure you are infusing at. See the pump capacity diagram for that, as cfm decreases with more vacuum)
