No, I don’t see why it would, it would just waste resin. The only reason release film effects anything is because it creates a bigger difference in the flow front. Your flow front isn’t even, what you are witnessing happening on top of the laminate is delayed on the surface of the laminate, so the flow front on the surface of the laminate will be lagging slightly behind the flow front that you can see from the top. Release film makes this difference even bigger as it takes more time for the resin to penetrate down through the laminate stack, and so if you let it flow too fast then you may trap voids between the two flow fronts.
Throttling the resin flow is what will fix those issues, as it slows the top down and gives the resin more time to flow on the surface.
