Unfortunately, the internet is loaded with pictures of people who tried to fabricate molds and parts with only wax and ended up with severe sticking…especially those who work only with epoxies. The chemistry of the mold/plug surface, paints used in the process, and the layup resin all play a part in the quality of the release. When a new mold is made, not all molecules within the surface coat get chemically linked. This means that there are some open reactive sites on the surface of the mold. When you put fresh resin into the mold for part fabrication the molecules in the resin can be very eager to bond with open sites on the mold surface. Wax typically cannot block this reactivity and PVA is used to create a barrier. With a polyester based surface coat the PVA actually progresses the cure of the mold surface. Overtime there are no longer any reactive sites in the mold surface and the mold is said to be “seasoned”. Wax provides slip and PVA blocks the chemical reactivity.
On some plug/master surfaces the reactivity due to the chosen paints can never be eliminated and PVA is an absolute must. Some plug surface present no potential for chemical linking and wax is sufficient.
Aggressive polishing (above fine grit) actually damages the chemically reactive sites of some resin making PVA unnecessary. I personally never polish molds. Polishing plugs is so much easier. Since I don’t polish the mold surface I may have seen more chemically reactive issues.
The key is testing the entire process forward and backward before you commit to fabricating a mold or part with a chosen release system, plug surface, mold surface, and layup resin. Change any one and wax alone may not work. Change any one and some semi-permanent release systems will not work. I know of some epoxy resins that will not work with Frekote FMS/770-nc.
TEST! TEST! TEST!
I’ve seen enough failures to know that wax alone, without PVA, doesn’t work with every combination and process. In my opinion if someone recommends a release product/process they need to be very clear about the release surface and the layup resin.
Applying Wax & PVA
I allow 15 minutes between each coat of wax and about 1 hour after the last coat on new surfaces. I only apply 4 coats on a new surface. With Part-all Paste #2 I buff immediately after application. With Mequiar’s #8 I wait about 10 minutes before buffing. I’ve seen some people wait too long and then have to work really hard to buff. This can lead to over buffing. I prefer to start buffing too early rather than too late. I use two buff cloths. One to remove the skim/excess and one to buff to gloss.
The only wax that I know of that doesn’t cause the PVA to bead up is Rexco Part-all Paste #2. In a production scenario I wax and spray within 10 minutes. In one application I waxed once every 10 cycles put used PVA on every application. I personally would rather spray than wax and buff. Spraying PVA onto Meguiar’s requires multiple light mist coats prior to a flowing coat to prevent beading/fisheyes.
I use semis almost exclusively now. I typically do more complex parts so I’ve been able to get more than 3 cycles before needing to reapply. With some processes I need to apply a fresh application before each cycle. This still saves me time and releases are so beautiful.
