Attempted the second infusion today. Failure and success.
Success: Got a perfect bag. Had to chase some leaks with gorilla snot and acoustical sealant but managed. I picked up a couple of “Spy Ears” off of e-Bay. They’re kids toys that magnify sounds so kids can play spy stuff I guess but ya know? they worked great! For $2 plus shipping I thought I’d give 'em a try. E-Bay item #120149832296
Failure: The stupid semi-circle is a nightmare to infuse. I thought I was being smart setting up the perimeter vacuum and infusing the resin from a central point. Well sh*t! The epoxy immediately ran around the part to the vacuum outlet! As you can see from the pics it followed the minor bridging along the edges. This left a huge void in the part.
Success: We fell into Plan “B” after a half hour when it became apparent the remainder of the part wasn’t going to infuse. We clamped off the resin feed and relocated it to the center of the void. This was easier than I thought it would be and it worked. After the void was about 80% complete we sealed off the inlet and let the vacuum take over. I don’t know if there’s a void on the bottom but I’m assuming there is. That’d be cool then I can try a mini-infusion on the void there like you’d do on a repair.
Success: I used only a small semi-circle of flow media, enough to get the resin up and under the part. That worked well and the biaxial fabric flowed just fine on it’s own. I also provided a resin break of just peel ply between the part and the vacuum outlet which is probably the only thing that saved our bacon this time. We used about half the resin we did last time and I don’t think there’s more than an ounce or two in the resin trap.
No more semi-circles for me! I don’t know enough yet about how the epoxy flows through the stack. Well I know more than I did two weeks ago! I’ll demold the part tomorrow and we’ll see how we did.
