I thought I would add my feedback on using the MTI samples that I received a couple months back.
I used the sample on a piece that Ive made many times so I know the amount of resin that I need and the final finished weight. I always infuse from the center out using one of those plastic resin infusion connectors for 1/2" hose and spiral wrap on my flange, so switching to the MTI hose was as simple as replacing the sprial wrap with the MTI.
The directions given for the MTI say to plug one end of the MTI with tacky tape and attach the vacuum to the other end. I actually did the same as I do with spiral wrap and just made a loop and connected a plastic T to the MTI.
I am very happy with the results. Although I paint most of the things I make, if you are trying to make a pinhole free carbon fiber look on the surface of your part, the MTI will definitely help.
I actually think that if you use the MTI hose you dont even need a resin trap on the end of your vacuum hose. Resin just stops at the membrane. This stuff is great especially if you are infusing an odd shaped part. I always had the problem that resin would always reach the sprial wrap on one section before the entire part was infused. I had to use more resin than needed so that the rest of the part would infuse, but the MTI solved this issue for me.
The only downside that I can think of is that sucking air out of your bag does take a bit longer than when I was using spiral wrap. Other than for that, I really cant think of any downside, other than for not having a local supplier.
