My pump is outside and it’s already hot down here in Texas, so it generally burns off/evaporates oil at such a rate that the oil has to be refilled every couple of weeks. I know that a vacuum pump ‘burning’ (misting) oil is a bad sign, as it means there is an air leak that is actually misting the oil, and this is true: there is some pin hole leak somewhere deep in my plumbing that means I can’t get below 28.5" on my analog gauge, but I can’t find it and can’t do anything about it ATM.
The GDH electronic gauge is what GAC composites sells, so I will indeed be picking that thing up once I get some free cash to do so. I do my vacuum integrity check through a prolonged drop test, which also serves as an evaporation period for residual moisture. I usually give it around 30 minutes. My bagging line is fairly simple (a rectangle with just 2 pleats per side) so it’s quite easy to tell when it’s bagged properly and if there is a leak or not.
Hojo: Thanks for the tip concerning the greenflow. I’ll look into getting some redflow, which I know is a thicker product that allows more resin movement. Interesting to hear that it could be introducing surface imperfections. Although I think my void problems are unrelated - in my case, there is a very hard corner, perpendicular to the flow front, that resin appears to be racetracking to somehow and then filling. This occurs before the area immediately before this corner is fully wetted out, or at least I think that’s what’s happening. Luckily, I think I can get away with just cutting the IM extra short, it’ll only result in an extra inch of carbon that the resin has to flow through without assistance.
Of course, I’m out of my required fabric now so I won’t be able to make another test until the end of the week
