The MTI hose limits the amount of air that goes through per unit of time. What you see when using it, is that once you turn on the pump, the membrane is pulled against the spiral that is in the MTI hose (at least then you know for sure you closed the end of the MTI hose) and the bag will evacuate slowly, much slower than when not using the MTI hose. It also depends on the length of hose, and part size.
A tip is to evacuate a lot of air using a vacuum cleaner, just before taping the last bit of bag. Especially with larger objects this is advisable.
