turns out the leak was coming from my ball port on my vacuum draw line. when it’s shut off but connected to the vacuum pump hose it doesn’t leak (hence it not showing up in my drop tests), but after I infuse and disconnect it does.
So with that being said, I’m still fairly certain this void/bridging isn’t a result of an air leak.
I put a part under with just peel ply and then infusion mesh yesterday and am going to demold it later. No perforated release film so I’m guessing it’s going to be a huge PITA to release, but at least it’ll show me if the problems route cause is the PRF.
If anyone has any tricks for release IM off of just peel ply without using a perforated release film I’d love to hear them. Soller said that they commonly spray their already factory coated peel ply with 770nc and it helps, so I’m considering trying that.
I’ve tried releasing with econoply E (cheap stuff) and econolease (the good stuff) so far, both with very little luck.
