Yeh I think that is what is causing your dryness issues. You should clamp the vacuum line first, then the resin line. Unless you’re using MTI hose, you really shouldn’t leave the pump on and the vac line open.
And yes, the resin will move slower without the mesh. You should try to get the mesh as close together as you can, without making it go around the corner on your mould. So try to cut it the exact shape of the part, so that it sits nice and tight inside that radius. Then cut the pieces on the flange to shape. This way, it’s ONLY the radius on the mould that has no mesh, which is quite a small gap.
