Sorry for the delay,
Can you step through the finish technique you used to get that perfect clear gloss surface? I see you strip off a sort of peel (what is that stuff?)
I use 0,25 mm thickness PET sheet, usally it has a good finish (put some demoulding wax after using it).
How did you like the double wing foil compared to a single?
the double wing is less sensitive to the turbulence and the foil need less speed to start working, it as also a good stability.
Now the new foils are finised and tested.
I add some pics and, as soon as I can, the new two videos (constructions and trials)
