More practice parts.
First a short video of degassing the resin prior to infusion.
http://flic.kr/p/bf8V3v
This time I made a 12x12 square, with a 10x10 foam core. I fed from the middle, and pulled vacuum on the sides. I also put 1/8" diameter perforations in the core every 2" from the center outward. I think I probably over-sized the holes, but it worked. I’ll try smaller holes next time. That test was to ensure resin would wet out the surface underneath the foam, with just small holes to pass through. I discovered that sealing a resin feed hose in the middle of the bag isn’t easy. I ended up with a leak during infusion. I was unable to stop the leak and figured the parts were destroyed. I was wrong. The infusion still went quite well. There is an area where the resin didn’t 100% wet out the fiber where there was a significant amount of air, but its not too bad. Nice lesson to learn on a practice part. Next time I’ll feed the resin tube in under the bag edge seal like I’ve done in the past.
Perfectly transparent fiberglass.
IMG_5573.jpg by Kevin_Doe, on Flickr
Then I also made a 4x12 test panel with a 2x10 foam core, out of carbon. 2x2 3k twill weave. Two layers, core, two layers. This test was to see if carbon infused any different than the glass. It seemed to wet out quicker, but other than that no other issues. The test panel turned out really nice. The carbon panel is super stiff as well. This stuff is awesome.
Mold side
IMG_5593.jpg by Kevin_Doe, on Flickr
Peel ply side.
IMG_5589.jpg by Kevin_Doe, on Flickr
Next test will be a small swatch of carbon epoxied on the mold flange, to make sure that wax alone is adequate to release from the gel coated mold surface. If that goes well, then its on to making an actual sunroof. Well, I may do a test to thermoform some of the core inside the mold, but that should be straightforward.
