Epoxy expert Q:
So, so, true!!! No reason to ever buy from them.
If you want to make your own surface coat you can mix cabosil in. make sure you mix it very well no lumps, you can also use aluminum filler.
A good way to get the lumps out is to sift the cabosil with a flour sifter before you mix it into the epoxy. Works really well.
“tried contacting nfg through their website one time with no return response”
Well that is just nfg:D
