KISS method.  Don’t look to deep when the answer is right on top…
I’ve had similar results in which you describ with duratec.     I really do believe temp , humidity and timming is your enemy.
BTW I grew up in a pannel shop and I paint 2k almost every day.
In summer months no problem with curing times , but high humidity can cause a few issues.
But with yours you say you wait a few units before you apply next wetter coat ?   At the temp’s you describ that it would be impossable to not make it fish eye if you don’t  leave it long enough.   It will simply melt through the first layer or mist coat and fish eye everywhere.  This is why it look good for a few moments and then fish eye’s… It the time needed to melt through and then separate from a dust piont.    ( pin holes are different)
With highly mirror polished 2k painted plugs with TRwax release …in low temp I’ve had to wait at least 20min+ before doing a 2nd light coat and a 3rd before doing a proper full coat.   And sometimes do a small hand size test pannel to check results before proceeding to main job.
The FINGER print test is the best and only way your know that it is ready for another coat.   This way you can get some consistency in " ALL " temp conditions.  There has to be enough time for esters to be evaporated out of the first coats and it dries enough so the next coat doesn’t melt it.
Very similar technique to using 2K , but duratec takes longer, much longer  in cool conditions to gas off due to it’s thicker viscosity and chemical make up.   Chemical bond still happends along time after spraying so don’t be worried about leaving it to long 15 to 30+ is fine.  ( similar as 2k).
But in those temps probably 15mins and the finger test will come up with it on your finger.   You need to be able to press firmly and make a finger print but not get any on your finger.    This is not a light touch , more like medium press to a bruise on you leg and make it hurt.   Not hard press but not soft.
On really glossy plugs , I find doing a few lighter coats , good drying time in between before I move on to the filler coats I have no probs.
Cheers
Tim
