If you Google the terms “carbon fiber CNC gantry” and “carbon fiber gantry beam”, you’ll find 2 companies that offer a carbon fiber CNC machine products.
One seems to sell custom CNC routers with a milled carbon fiber gantry and other milled cf parts. I’m not sold on this approach at all. Milling solid blocks of cf for parts that big seems wasteful and sub-optimal but I’m not 100% sure on this view…
The other is a custom carbon fiber parts business that makes and sells custom carbon fiber beams for use as gantry bridges and other machine parts. They look quite good.
The latter appears to use some kind of compressed cf reinforced polymer. Neither use woven cf laid in molds like most of us use here.
Using a sheet molding compound for cf CNC components makes sense to me for this purpose as it offers greater multi-directional rigidity, is cheaper to manufacturer in larger volumes and easier to mold into complex shapes. With that being said, I am not sure the multi-directional rigidity is needed for this purpose as it seems like the parts would be under stress from 3-5 predicable directions (as the router moves on rails).
I am making my cf parts in traditional molds but I am using a mix of regular woven cf fabric, bi and tri-axial fabric, random matrix carbon fibers (made into a sheet molding compound) and carbon nanotubes mixed into the resin for some of the layers.
For my cf gantry bridge, I am using a rectangular woven cf outer shell with a bunch of .75" carbon fiber tubes inside as reinforcements set in cf sheet molding compound. My plan is to use a double-bridge design. One regular gantry bridge to hold the Y and Z axis rails and a second bridge under the table connecting the bearings between the X-axis rails. I believe this square gantry design will offer greater rigidity than some of the traditional 3-sided gantry designs. We’ll see…
I am also adding some steel plates in select positions inside the cf gantry parts to hold the screws needed for my THK rails.
I think the design I am working on will provide the greatest rigidity possible without going over my budget but due to my lack of experience, I am not really sure exactly how much strength and righty I actually need. I am positive the design will offer significantly greater righty than any of the comparably priced desktop CNC routers on eBay or any of the diy kits available.
The aluminum build parts I initially ordered from Open Builds parts store were real garbage. I could literally bend their T and L brackets with my fingers. They went straight in the trash so the bar is relatively low…
