Hello,
have you degased your resin? If not the airbubbles can not go ahead and will be enclosed in the soric and durface layer. I always use a flow media, even with soric. The print through can be reduced by a lower vf that can be realized very easy with the MTI hose. But the vf depends on the application.
The airbubbles can also be produced if you have less resin in your part, don’t clamp to early.
Wich vacuum level do you have? Your vac level should be 20 mbar / 0.006in hg absolut
Use flow media and let it end 1" / 2cm before the MTI hose. Place the MTI hose direct to your part and clamp resin feed when the resin reaches the MTI hose.
Soric does work as flow media, but not very good.
