At this point, it’s time to start molding some tubes. If you’ve done the math correctly, you should be able to apply the materials you may require under the tube (release film, peel ply, etc), apply the reinforcing fabrics (wrapped tightly around the bladder and wet out) and still be able to place the assembly into one half of the mold with a little room to spare.
Place the second half of the mold over the first and install the locating pins/bolts to maintain alignment. Space your clamps evenly along the length of the mold and snug them down.
Connect the end fitting to a compressed air source and begin ramping up the pressure. This requires some experimentation but for most of my tubes I increase the pressure about 5psi every few minutes up to about 35-40psi max.
One thing to be aware of: the excess resin and the air between the bladder and the mold needs to escape in order for the laminate to evenly get compressed against the mold surface. This means that some resin should be squeezing out between the mold flanges and dripping all over your bench. This is why I keep my alignment bolt locations outside the area of the mold that makes up the length of the tube. If you have alignment bolts in the path of this excess resin, you’re gonna have problems.
It also means that mold release should be applied to the flanges of the mold as well as the cavity itself. a very thin film of resin should be evenly left on the flange after the mold is opened.
If the mold is closed too tightly, this excess air/resin cannot escape and the process will fail.
Also, at the pressures used, you’re dealing with a fairly large amount of force inside the mold. woodworking clamps or some other light duty clamp WILL NOT be sufficient to ensure safe pressurization of the mold.
A failure during pressurized molding could range from best case; the bladder bulges out between the flanges, pops and your part is ruined or worst case; the clamps fail and the rapid loss of support results in catastrophic failure of the mold.
Think ahead, over-engineer and work slowly. I guess that goes for just about everything.
After curing, you should separate the mold halves to find something that look like this.
