This is probably too late for you, but for others that may need this information;the SprayMax rattle can 2K clear can be wet sanded in 24 hours at 80F.
The longer you let it sit, the harder it becomes and the more sanding you will have to do to remove the orange peel. However, it takes a shine better if you let it sit for 48 hours or more before polishing. Of course, the time is reduced at higher temperatures.
I usually knock the surface down with 800, 1000, 1200, 1500 and 2000 used wet and then wait another 24 hrs to compound and polish.
The SprayMax is great stuff BTW, particularly if you intermittently use only small quantities, like I do. Yes, it is not cheap at ~$23 a can, but it is far cheaper than a $70 quart stuff that goes bad after using only 1/4 of it.
It takes some practice to get it to lay down nicely (light coat then 2 or more wet coats) and not run or form drapes and you will get some orange peel since you have no control over the pressure. It took me a couple of jobs to find the right distance, speed and flash time, but now that I understand how it behaves, I use it a lot and am please with the final finish.
S//
