You can buy 80/20 extrusions and parts on ebay under their seller name there. Cheaper probably.
I was looking for some aluminum plate the other day and found them on ebay.
http://stores.ebay.com/8020-Inc-Garage-Sale I’ll probably end up buying/cutting some mild steel at work and then having it all welded together.
20_RC51_00, keep us updated… I am in need of building a post cure oven myself. Also i may do some high temp parts in the future… 350F at the hottest.
That 80-20 looks like the stuff to use for a frame, but those plastic connectors they have won’t cut the mustard.
Some may laugh but i do the same stuff as RC51 does, i’m thinking a small oven 1ft tall x 3ft deep x 3ft wide. Put her on legs and wheels so i am able to roll it around.
Caswell plating forum has an oven building forum… thing i noticed with most of the guys there they’re building ovens that will do 1000F + so their elements and controllers are overkill for what we need. I’m thinking of buying two toaster ovens and tearing them down for their parts for use in my homemade oven. The only other thing i can think that i may need is a fan to circulate the hot air. The toaster ovens are 1500 watts each.
