Yep agree with worldwealth. You must heat the molds, all mine are heated to 40 C + (around 110 F +) and remain so throughout. Also heat the resin to lower the viscosity it will also help disperse any remaining bubbles in the pot. If the chainguard is taking 10 mins to infuse, the cloth is most probably not fully saturating and trapping air hence the air between the weave.
All my moulds sit on 7, 8 or 9 inch high boxes with light bulbs inside, the number and placement varies depending on mold size. So i don`t get a mold hot spot i lag the underside of the mould with foam backed foil (radiator reflecting sheet) To warm the resin up grab an old microwave from the small adds or if you are using a small amount use a heat/hot air gun on the cup whilst stirring.
Attention to these details will i am sure give you the results 95% of the time. The other 5% well even the pros have disasters even if they dont admit it lol.
Baz
