Using this (silicone mandrel technique), if my CF layer is approx. .072 thick how much gap do I need between the mold and mandrel? -
What is High CTE? -
Does the silicone expand after it is heated? If so I could make the (mandrel) even smaller than the thickness of the material (so you can get the mold closed without pinching/wrinkling? -
FWI, Pre-preg & aluminum mold. -
When I put the mold together, does the fibers bunch up at the parting line or other places? -
Is the (silicone mandrel technique) forgiving? Meaning do the layers of CF have to be perfect in the layup? -
Reason for the locators is to hold Center Lines for assembly of the final part. - How do you hold the two silicone pieces together for layup?
Using this technique, can I reuse this mandrel over and over again?
The layup will me similar to that “smart tooling” mandrel I showed earlier in the thread. Could you PM me the info on the silicone?
