Advanced technique questions
Thanks Herman ill give it a go tomorrow. I ran out of resin. The second one I made relief cuts, and cut off the woven end I assume that’s Kevlar. I always wet the mold first then lay the cloth. I also leave the bag under pressure until fully cured. I guess we shall see. Lol
Oh quick question if I have a 5.7 3k 2x2 twill and a 7.0 oz 3k 2x2 twill how do they differ? I’m assuming they have the same amount if threads but the thickness of each thread is larger on the 7.0oz. Is this correct?
No, the threads are the same thickness (3K) but the thread count (number of threads per inch) of the 7 oz is higher. In your post number 14, you show a plain weave. See the gaps between the fibers? The 7 oz probably has no gap at all. I even doubt the plain weave you show is 5.7 oz, it looks more like 5 oz or even less. (160 gr/m2)
