Thanks guys for all the replys.
Have a clearer idea of what to do now.
I have to balance several factors, with different relative weights:
Weight: 30%
Stiffness: 30%
Impact: 20%
Cost: 20%
That is, I have to have a lightweight structure that does not deform (or deforms not much) under load. It has to have some impact resistance and the cost can’t be prohibitive. That being said, could I have some comments on the following layup?
1 layer 0/90 200gsm twill carbon fabric
1 layer 0/45 170gsm twill kevlar fabric ( for impact resistance)
1 layer 0/90 245gsm twill carbon fabric
6mm pvc foam core (airex or divinycell)
1 layer 0/45 245gsm twill carbon fabric
In my original layup I stayed away from unbalanced laminates because as it is a case and it needs to close (i.e the edges have to be perfectly alligned in both case and lid) I was afraid that with resin shrinkage I had problems in that area.
I may consider inserting a longitudinal reinforcing inside brace of 1 core layer+ 1 carbon layer for added stiffness ( the case has a lenght of over 2m)
Another thing, is there any advantages in this fabric :
Carbon/Kevlar Hybrid
