I have watched this video countless times and used it to “learn” how to do an infusion.
I am aware that there are many methods of how to do it and they also state that in the video at one point.
I am also a member of the easy composites forum, the people who produced the clip.
They do seem very knowledgeable indeed and have been helping myself and others with all sorts of projects, including very complicated ones. So it leads me not to question the procedures in the clip. Now that I am here as well, I do question some of the things that the guy in the video does as well as some of the posts on here.
The double layer of mesh at the vac side is to soak up excess resin and allow a vacuum pillow for free flow out of the other side. He clamps the feed line first and subsequently the vac line 5-10 seconds later to allow the airated resin to escape.
The infusion starts with air in the feed line because it needs to be placed in the feed pot in the first place? he allows that air to escape before clamping the line.
Clamping the line makes perfect sense to me (if the bag is 100% sealed).
What I dont quite understand is, why some leave the pump running. Does it not cause the resin to be sucked back out of the part and into the catchpot? Wouldnt this result in too much resin being drawn out and resulting in a pin hole surface?
People argue that leaving the pump running during cure is a safety measure incase there are small leaks, but the pump will consume oil and gets very hot and may burn out if not pulling against a full vacuum.
A lot of questions and I am still very new to all of this, but highly interested to see some of your replies.
regards,
Fabian
and of course very light.
